Best program for searching for IP addresses
It is also incredibly useful for waking up, and causing panic, among the IT/Network Admin that might be at the building/campus you are visiting. It isn't malware in-and-of-itself but it certainly triggers all the automated detection systems that those people might have running to try to protect their network.
Last year I was doing a job for a large multinational to assess some of their cyber security and cyber attack preparedness. The works started by identifying and documenting every last ethernet device on their controls network (around 1500 devices). I used a lot of the tools mentioned in this thread already, and some other more "manual" techniques.
In the first month, I had to respond to no less than 6 "what are you doing on our network" queries from the global IT team who repeatedly saw my laptop doing "suspicious" things on their network. Which did in many ways lead me to believe that they were quite well prepared for a potential cyber attack :ROFLMAO:
Advanced Port Scanner, free & without limit, I have scanned networks of 512 IPs.
It will also tell you the name of the device, if it can figure it out, and what ports it is listening on.
Thanks all, I am catching up with feedback and love this site. Actually, I will probably try a number of these if I get the opportunity.
Hello Everyone, I have about 135 controller PIDE loops that I need to add to my Studio 5000 and that means I will probably have to create about...
1,915
Good Evening . I visited a pump station sight today that has a PLC-5/11 CPU. I was given a CD with only a file with a program and extension of...
3,766
Long time reader first time poster. I have the following pulse signals as attached generated by an OEM machine. I am aiming to recreate the...
19
5,241
So to start with, Iā€™m pretty new to the field. I work as an E&I tech (one of four techs) at a food manufacturing plant. For the most part, we are...
1,834
I am having an issue with my flex I/O analog over Remoto I/O. I want to post my zipped program, but the file is over 3Mb. What is the best way...
2,197
