FIFE Line Guide sensor interfaced with plc
not4u2c
Feb 2009
sc
I'm looking at a FIFE SE-46A line guide which, according to FIFE, will give a 0-10ma signal output depending on where the line is currently located in the entire bandwith of the sensor. I would like to interface this sensor with a micrologix plc which will be used to control two outputs moving a hydraulic cyclinder left or right, based on the sensor's feedback. I'm trying to figure out how will I know if the line is to the left or to the right of the sensor??? What signal will I get? Does a line on dead center mean 5ma?
Going back to my brief time in tissue manuf. FIFE web-guides were used.
The web-guide, unpowered, would be offset to approx 5 degrees (allowing the web to track off-center). The web is put through the web-guide rollers with a web-edge below the sensor. If the web covers the sensor fully then a hydraulic cylinder will correct the alignment by driving the web-guide assembly towards the 0 deg. Depending on how much of the sensor is covered determines how much correction the hydraulic cyl. imparts on the web-guide assembly. If the sensor is totally uncovered the hydraulic cyl. allows the assembly to return to the initial 5 deg. offset. Obviously this is continuous control so adjustment will occur... erm... well, continuously!
http://www.fife-europe.co.uk/pdf/SE-46ATruLine_GB.pdf
http://www.maxcessintl.com/sites/default/files/documents/Fife_GuideOperation_0-104.PDF
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
42
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
When supplying variable frequency drives (vfd), should we install the line filter (emc) before the reactor (choke), or reactor before filter...
195
I'm a newbie who started a job as a repair tech recently. I've had plenty of luck with ABBs, Allen Bradleys, and a few others, but I can't seem to...
160
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
218
