Terry Woods
- Join Date
- Apr 2002
- Posts
- 3,170
LadderLogic added this to the end of a thread where I thought it might get lost in the clutter.
I think it's a good question and deserves a place of its' own.
LadderLogic said...
"I am having a nagging feeling here... so I will ask an extremely stupid question (and I am profusely apologizing for doing so).
What is the difference between a synchronous permanent-magnet 3 phase AC motor and a brushless servo motor? You know, one of those with 3 phase AC windings and a permanent magnet rotor...
If someone fits the former with a position feedback device (such as an encoder) - would it make it the latter?.."
BTW, LL,
This is not a stupid question at all. It's a pretty good "informed enough to ask the right question" kind of question. (As opposed to those "I don't know enough to ask a reasonable question" kind of questions... as in, "What are PLC's and what are they good for?")
Your everyday, 3-Phase Motors suffer from cronic-slippage. That is NOT necessarily a bad thing. It produces TORQUE... that is good.
However, that motor, or rather the driven device attached to that motor, is not necessarily moving at the speed or in the position that you might expect.
The control of the speed is generally open-looped. That is, nominal is nominal. Some programmers make speed estimates using the nominal speed value... ignoringing that the speed starts at zero-rpm.
Position indications are generally made using actual input sensors telling the location of the driven device. Although, some programmers try to use the speed-time to calculate position.
Servo-Motors, with absolute Rev-Position Indication Feedback, are able to provide the controller with a real speed value and a real position value. Torque is developed by manipulating the timing of the constructed 3-Phase signal to the motor. This works in a way very similar to the method used to automatically advance the timing in an automobile engine.
While the Servo-Motor is turning, the controller, through the encoder built into the motor, is aware of the speed and position of the driven device. Of course, this requires that there be a known relationship between rotary and linear motion. As in, so many revolutions equals so many inches in linear travel.
So... the difference between the two...?
Their ability to control Position is unquestioned (8000 counts per Rev!). A 3-Phase Motor, on a drive, can have an encoder but it can't move to Count=XXXX.
Their ability, through their controller, to manipulate TORQUE on demand is better. 3-Phase can't manipulate TORQUE without additional slippage, but then, in 3-Phase, position control suffers.
They can follow a profile much more accurately and stop on a count (or two).
And now, the other shoe finally drops...
Servo-Motors, with their Rare-Earth Magnetics, are much more expensive. Although the advantage is GREAT,,, in some applications.
LadderLogic said...
BTW, LL,
