FTView Studio ME communications issue
LMBrian
Sep 2012
Florida
54
Having issues downloading a runtime application to a PV1250 using ethernet cable. The source file selected is correct and 'internal storage' is selected as the destination storage type. The IP address is correct for the HMI and we have 'pinged' it to ensure it also. After 30 seconds or so the download times out with the message 'destination path does not exist'. Does anyone have a link as to how to configure a device in RSLinx Enterprise? Or am I on the right track? Thanks for the help.
If you can browse the device in RSLinx Enterprise in order to select its icon as the target, then your configuration has to be correct. Just using PING doesn't really tell you much other than that there is some device on the network answering to that address.
It's possible that the error message is a symptom of media or traffic problems on the network.
Is this a terminal you're setting up for the first time ?
Is there ever a progress bar, or just the timeout ?
If I'm having trouble using the network to download to a PV+, I just grab a USB or SD/CF memory device and load the program manually.
Looks to be my week for FactoryTalk issues.:banghead: When trying to set up a new topic in FTView Studio communications, the Communications...
7,373
Hello, I am attempting to complete an HMI project using FT View SE. The controller I will be reading is a PLC 5/30 that is on DH+. I can browse...
2,182
Hello Experts, I am trying to create a SINE Wave generator and i cannot seem to make it smoother. I have done this before but i forgot the exact...
290
Hello all. Is there a way to upload alarm tags at the bit level to my FTView studio? I export them from my PLC thinking I will upload them to...
408
Hello all. Many years ago I programmed an Omron PLC and HMI and I was able to control which display was being shown on the HMI from the PLC. Is...
334
