Do you folks know of any tachometers that the output is 4-20 ma
Aug 2016
Virginia
343
Good Morning ,
I am working on upgrading two machines. I would like to put a tachometer on a outgoing conveyor. These machines are remote and moved around alot. I have a small main panel that is stationary with the PLC and Frequency Drives in it. I am using Flex I/O on the portable machines , and just using a plug for the motor connections to the drives , and another plug for ethernet. I do have a Flex I/O Analog Module that I can use for a 4-20 ma tachometer output . I could use an Ethernet I/P Tachometer , if it is easy to configure in a CompactLogix PLC .
Do you folks know of any Tachometers that have a 4-20 ma output or Ethernet ? I see that Allen Bradley has some. What would you recommend ?
Thanks so much for your help.
Thanks for the suggestion . I love the idea. I need to see the actual speed of the belt. There are alot of things that influence the belt , a rotating mold , air pressure on the belt , etc. that causes the belt to possibly slip . That is why I would like to see the actual speed of the belt.
Thanks,
Good Evening , We had a Mettler Toledo Safeline Metal Detector acting unstable last week . We brought Mettler Toledo in to look at it ...
828
Good Evening , I have been asked to do some teaching at a community college for industrial automation for some young adults. I'm thinking 2...
28
10,863
Hey All, I've got a Sullair LS-16 (V160) compressor with the 3-line Supervisor controller (identical to this...
2,458
Good evening , I was looking thru some Rockwell Automation programs , and took notice in some programs , UDT’s , AOI’s , etc. the NOP...
3,169
Good Morning , I have a lot of projects going on and it seems more helpful to stay in the office and work on multiple things , than run to...
1,480
