Micrologix 1200 fault
jglass
Nov 2005
Genoa Illinois
I have a Microligix 1200 BWA(about 5 years old) with the fault light "ON". The Green "ON" light is also lit which indicates the PLC is not dead. No changes were made to the program. All I was doing was replacing microswitch input with sensors. The PLC had not been powered up for nearly a year.
I was able to download a new program and reset the fault. 30 minutes later, the PLC returns to the fault state. I repeated this 3 times, now the PLC will not communicate with my laptop so the fault cannot be reset.
Was is up with this PLC? Can it be corrected? Should the PLC be replaced.
Any ideas appreciated
Jim Glass
Genoa Ill.
It has been 2 weeks since I played with this thing. As I recall, Communications were re-established and another program from the laptop downloaded. It was not possible to view the faulted program. I did need to switch from the faulted mode to run mode after downloading.
Jim
If it happens again, go online with the processor before downloading a new program and look in the status file to find out what the offending fault was.
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
505
Hello, I have a Micrologix 1200 1762-L24BXB PLC and as soon as I power it up with nothing connected to it, the power LED and the fault LED both...
3,736
I have a 1200 C displaying the Fault light . With no additional I/O connected I cannot clear it. I cannot connect to it with the fault existing ...
2,242
Hi friends... I have a problem with my plc micrologix 1200 mod 1762l24awa today has a fault and i cant errased... the fault said...THIS IS A USER...
4,176
I'm working with HSC functions... here goes is there a way of eliminating the fault routine or major error when the High Preset is the same as...
7,563
