Working and load memory
mass89
Oct 2017
England
77
I am looking for a guide on how much working and load memory I require for PLC CPU selection.
I am particularly interested in the s7-300 range but how do I know whether it is a 64kb working memory or a 1mb working memory cpu I require, same with load memory for the card.
Is there some sort of guide? I spoke to siemens and they may aswell have told me to just guess the size I need ;)
This will show you how much is required for program you have already produced won't it?
To get to that point you would have selected hardware already in the configuration (I think), Unless you can make a program without selecting hardware, then see how much memory required and then select the required hardware?
You can create your program with any S7-300 CPU and as already posted get the sizes from the blocks folder properties. Once you have created your program you can then select a CPU which matches your memory requirements.
On or around 2020 the S7-300 CPUs will be phased out but still available for spare parts (read much higher cost). I would consider an S7-1500 CPU for a new project.
Hi, I have a problem with a GET instruction in a s7-1200 communicating with another s7-1200. It all worked fine until yesterday. I made some...
5,500
Hey All: I'm just wondering what your thoughts are on the following. I have a 1746-SN RIO Scanner that suddenly stopped working after we powered...
2,881
I need your help to learn how to load the program from a working Honeywell MiniCOP module 627-1002 from 620 series PLC and then to download it to...
2,016
I'd like to download WinCC ,but after doing many searches on Google, i can not get a free download link ! so i hope someone can give me a free...
2,238
Hello All, Brand new G308 (Just getting redy to ship out to the customer). Powered up Today and no longer can down load using USB. 1. Unable...
3,951
