Kinetix 6000 servo drive fault of E04, motor overtemp fault
unsaint32
Oct 2012
minneapolis
365
I kept getting Kinetix 6000 servo drive fault of E04 (motor overtemp fault). The servo motor is MPL-B450F. The motor was barely warm, certainly not enough to trigger motor temp switch.
Two wires from the motor thermostat is terminated on the Kinetix wire terminal # 6 & 11 according to the online manual I found here. http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2094-um001_-en-p.pdf
I'm attaching a screenshot from the manual.
Since the motor was not hot at all, we jumpered these two terminals and then we no longer get the E04. Had anyone have same experience?
BTW, I had to jumper the terminals AND leave the thermostat wires to the terminals (so two wires on each terminal), otherwise it wouldn't work. Doesn't make sense, I know.
E04 MotorOvertemp Fault (Motor Overtemp) Motor thermal switch tripped
• High motor ambient temperature
and/or
• Excessive current
Motor wiring error. Check motor wiring at MF connector on the IAM/AM
module.
Incorrect motor selection. Verify the proper motor has been selected.
These are other considerations from the manual.
Regards,
Garry
http://www.accautomation.ca
and/or
• Excessive current
module.
Regards,
Garry
I already checked the mf connector. no motor wiring error. Correct motor.
Hello All I have a machine built in 2013 but never commissioned. I have it almost complete. It has 2 Kinetix 6000's with a CompactLogix L43 with...
1,197
The homing watchdog timer preset was changed to 60 sec from 30 sec due to servo homing taking too long. The home offset is around 180 degrees...
1,928
Gents, I'm asked to check if an SEW servo motor with Hiperface encoder can be used with an Kinetix 6000 sercos servo drive. When I check the...
3,498
Gents, I've an Allen Bradley Kinetix 6000 Sercos servo system with 2 motors on a rigid construction. Both motors have the same gear ratio to the...
2,671
Hey everyone, Recently our maintenance department has been having all kinds of trouble with servo motors and i would like to build a servo test...
2,179
