I have a pick and place that is controlled by a Kinetix 6000 and Control Logix 5000. It consists of two motors that drive a pick and place by means of a cogged belt.
It has brakes that are employed only when the PnP is not under servo control... just to hold it,
When the brakes are released, the PnP will fall due to gravity. So when the PnP is moving down to do a place, the motors must hold it back so that it does a controlled descent.
Sometimes this results in a "shuddering" of the PnP. I am convinced it is not mechanical, but something in the properties/ programming of the Kinetix axes. The pick head has been modified so that it does not weigh as much as it used to.
What could I look into check or set that could cause / relieve this?
I have the stuff online in front of me.
thank you
thank you
