RSView32 Tips and Tricks: Backdoor tag creation on runtime package
TConnolly
Apr 2005
Salt Lake City
6,152
I'm sure that many RSView users have had this problem.
You develop an application using RSView32 Works. The application is deployed on a machine under RSView32 Runtime. Later on it is necessary to add a single alarm or some other tag to the equipment, but you can't shut down the process or take the machine offline long enough to update the RSView32 project.
Well, there is a simple trick to add a tag in RSView32 Runtime while the app is running without using RSView Works and without resorting to VBA.
Press CTRL-ALT-P to open the project window. Open the command line (System->Command Line) and click on the elipses (...) button to open the command wizard. Pick any command that requires a tag argument (AckAlarm, Set, etc). Browse for a tag name. When the tag dialog box opens navigate to the folder where you want to place the tag. Select a tag to edit, or click new tag and configure the tag as well as any alarms. After you are done the command line will contain a command string. Delete it if you don't want it to be executed and close the Command Line window.
Very slick, Alaric. I have saved this in my Allen Bradly TIPS file, with a credit line to you, of course!
Interesting trick Aleric. I will have to try it the next time I am on one of our RSView Machines. I have also saved the text. Thanks.
Stu....
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
368
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,904
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
592
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,423
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,299
