Using Patlite la6 via modbus
secs
Aug 2015
Office
65
Hi all.
Has anyone had any success using a Patlite LA6 signal tower via modbus? I have been reading the manual and trying to work out how I get a certain pattern to appear. As in I set up a pattern and upload the files. I want to fire up group one.
the manual says as an example
5.3.3. Register Address
The register address list supported by this product.
Register Address Control Allocation Data Condition
7 (07H) Smart Mode MSN 00H: doesn't control, 01H: controls
LSN 01H-1FH: Group Numbers 1-31
are these numbers represented as HEX etc?
Engineer
Did you have any luck getting this working?
The manual wasnt written from a PLC programmers point of view. It almost looks like the PC section of the manual
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
87
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
184
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
50
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
95
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
92
