Pinout of cable between pc and IAI PCON driver
eddiechiacp
Apr 2010
singapore
Hi, does anyone have the pinout communication cable between pc 9pin to IAI Pcon motor driver, currently, you need a rcb-cv-mw and cb-rca-sio to communicate between pc and Pcon driver. Is there a direct way or cable that does not require a unit of Rcb-cv-mw or rcb-cv-usb??
Pretty sure there is no direct connection available.
I understand that the PCON communication is RS485.
I tried to use a USB to 485 converter and connect directly, it fired the PCON.
Hope this will help.
hi gtsuport,
You have wrote that you have tried using USB to 485 converter and connect directly, it fired the PCON. What do you mean "it fired the PCON". Is it working?? or fail??
"It literally smoked the comm port.
White smoke came out of the PCON.
Ended up replacing the PCON with a new unit."
How you do it???
I have tried PCON,RCP2 and RCA driver with usb to RS485, it work fine, I dont see any SMOKE coming out. I put it for run non stop for 5 hours and more till now, it work fine. I like to know how you connect the pcon to rs485 converter, that you can see smoke ??
how exactly did you wire the PCON to a 485 adapter? I have a usb to 485 adapter and an old pcon to serial cable. Im wanting to make a usb cable I can use
Diagram Cable connect USB-Rs485 to PCon?
How you do it???
Can you share it ( Diagram Cable connect USB-Rs485 to PCon?), thanks
Anyone happen to know the pinout on the RJ12 side of a GE HHM cable? It's just a serial 3-wire and I know the DB-9 side. Thanks.
1,072
I need to emergency fabricate a cable to program a Parker 690+ VFD. Part # CM351909 I believe. RJ6 on one end, DB9 on the other. I cannot find the...
2,293
Gents - hope somebody can help out, I've been tasked with fixing an OLD SCADA system. I've got an S7-226 PLC thats configured for Modbus comms via...
1,450
Hi, I know this is not a PLC issue, sorry. I have a Sick Safety Laser Scanner and I wanna get connected to check some issues on it. I do not...
2,713
Does anyone have a wiring pinout for an NES series drive programming cable? I have a usb to serial adapter so I just need a pinout for the rj45 to...
1,454
