FactoryTalk Historian failing to add points / exceeding point count
phuz
Jun 2008
Mohnton, PA
1,044
While I resolved my other issue, I am having some trouble adding tags to the Historian. Right click on application in FTView Studio, Add individual points, I select the tags, but get the error "Failed to create point on server. Exceeded Point Count allowance for Point-Source"
When I go to the Historian, the license shows a tag count of 500 (Total 1, In Use 0). I don't know why it's saying it's not in use because the Historian is running. There are 0 user tags in the Historian right now, and 139 pre-entered system tags.
Good afternoon, it's been a while since your publication. I wanted to ask you if you were able to solve the problem. Since I find myself with the same problem. Greetings.
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
84
Hello Everyone, I want to install and configure factorytalk Historian v6. I'm new to this. Can you kindly share some knowledge on installing...
71
Has anyone successfully migrated an older Proficy/ iFix Historian database into a new FactoryTalk Historian server? Trying to eliminate having two...
1,129
Has anyone ever heard of migrating data from an iFix Historian into a FactoryTalk Historian? I am betting the easiest thing to do is to just keep...
1,468
Has anyone put together a package and implemented FT Historian? Is it really necessary to pay $1,200 a year to have your Historian talk to your AB...
1,496
