Easybuilder Pro, trying to make a world lamp blink
Zabido
Jan 2021
Australia
Hi, I'm an intern student engineer and I'm tasked with creating a HMI for a control system in EBPro.
I need to make an object (motor) which has four states that are triggered by the numbers 0 to 3. This is fine using a word lamp but 2 out of the 4 states require the object to blink. I can't find anyway to do this in the program except for using a bit lamp.
I have thought of maybe using bit lamps to overlap eachother but that would mean I would have to change the tag address for each object in the PLC program. Is there an easier way to achieve a word lamp like object which can have both static and blinking states?
Thanks in advance.
https://www.bing.com/search?q=weintek word lamp&PC=RIMBINGD&A=results
Thanks in advance.
First time I read the term "word lamp".
Search
... but 2 out of the 4 states require the object to blink....
which states (values 0 to 3) should cause the object to blink?
and is the "object" something in the HMI or is it something controlled by some other part of the control system?
How would you make any light blink in the field..
What can cause something to turn on for a specified duration or off for a specified duration? Do you think you can set it up to do both?
Now as for the HMI.. Most HMI's have a myriad of animation functions.. You can affect line color, fill color, touch, enabled/disabled touch. visible, etc. Maybe there is one that will do what you want based on a in plc value?
I have EB Pro installed on windows 11, I can open an existing project and edit but when I got to parameters tab and open page I get the hourglass...
48
Hi, I would like to know if it is possible to modify the properties of an object via a macro? For example I have a value of 100, via conditions...
858
Hello everyone Im Newbie to Easybuilder and im designing and HMI application where I gotta display a warning message in a pop up window...
1,764
I am banging my head trying to get EB Pro to convert simple math expressions. Ex: 1 Pump conversion coming from a SCP instruction O0 1.1 value...
1,840
Hello folks, I am working on an HMI application in EasyBuilder Pro using the software with the Simulation mode as an MQTT Edge Gateway. This...
2,042
