RS-232 Serial Connection to WAGO I/O-IPC 758-870/000-001 PLC Problem
allistondc
Jul 2013
Marikina City
Hello, I'm experiencing a problem with my project regarding the communication between a RENU FP5070TN-E HMI Touch Panel and WAGO I/O-IPC 768-870/000-001 PLC. I can't determine and configure the serial port settings for the WAGO 768-870 PLC and I've tried to guess all the port settings but still no luck in accessing the RENU HMI Panel. I've read manuals from WAGO's site about the configuration of the internal Serial port and the settings are programmed in CoDeSys but still i have errors in the program. Do you have a solution about this?
Thanks for the help and immediate response. :)
Still can't connect
I've also use that function. Can you guys check if the program is correct? In this format the RENU HMI still can't access the data from WAGO PLC. Thanks!
I recommend checking out the WAGO website. They've got plenty of ap notes and several that discuss working with the serial port. I'm more familiar with the 750 series so I can't be of more help.
Good luck,
Yosi
Hi , My problem is to connect, with a serial port RS232, a PLC Allen Bradley with a PC. I know that into a CPU of PLC there are 2 port :1 is RS232...
17,216
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,580
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,058
So I have a very old radio modem that uses hardware flow control. Its RS232 with RTS, CTS and RTD. I have pins: 2- Tx 3- Rx 5- GND 6- RTD 7- RTS...
1,556
Hey Everyone, I need to Interface Ignition SCADA ethernet network to an Allen Bradley SLC5/04 Serial RS232 DF1. Has anyone out there found a low...
1,014
