on ethernet switches there is typically one port that stands out from the others. Sometimes it is labelled "uplink".
I can imagine that it is supposed to connect to a level higher up in the network hieracy.
If there are many RJ45 ports and one fiber port, then the explanation is obvious.
But if all ports are RJ45 10/100, what is technically significant with the uplink port ?
