programming help needed
csides
May 2003
I am writing my very first ladder program and learning as I go. I am using a Keyence KV-16AR. I need a way to begin a timer when a certain relay turns on and stop the timer when the relay turns off. The elapsed time needs to be stored in memory and the timer then reset. Any help would be appreciated.
Actually, you've described the rung pretty well.
Open your software and do a search on Timers. Then look for a memory storage command, like Move, Store, Copy, etc.
Thos tid-bits should give you some direction.
TM
EDIT : One more hint - Retentive
This might help
CR Input
------| |-----------------------(RTO)
CR Input
------|/|----(OSR)--------------(MOV) timer acc to storage file
|________(RES) timer acc
Cheers
Sparky
Like this?
Code:
CR Input
CR Input
Anyone out there know how to change a old GE fanuc 90-30 versapro program into a logix 5000 program? If so ill make it worth your time
2,608
Hey guys, I added a few instruments to an existing program I wrote a few years back. Pressure transmitters, CV valves and so on. PID. For some...
1,658
Hi, I am new to PLCs and would like to learn basics and possibly use them in my projects. I would like to use a PLC to generate pulses for a...
11,301
Our local non profit railroad museum has a railroad signal that we need to program to operate in a specific manner. The lighting in the signal is...
23
7,703
Hello Gents, I am currently using AB CompactLogix Processor L36 ERM (Mid Range Controller) in an application. One of the device on the network is...
5,477
