G120 CU240E-2 PN Firmware Update
Hi as a beginner am learning about the G120 (CU240e-2pn) controlled by 1200plc 1-how can i interpret the hex values coming from the vfd...
125
Hi All CPU 1517F-3, Drives G120C Working on a project that is under development, so more IO will be added as we go along, to keep my drives out...
641
i have the CU240E-2 PN unit am documenting this PDF Converter with the CU240B-2 and CU240E-2 Control Units (siemens.com) the problem i have...
979
hi every one is t possible to power the (6SL3244-0BB12-1FA0) CU240E-2 PN unit with an external power supply 24vdc without the need of the power...
557
Hi All I have done the commissioning wizzard on the drive with Tia portal V15.1 and all good , but once i go to acceptance test and click on STO...
2,200
