PLC communications cable
wiley
Feb 2005
Having a new laptop computer with only usb ports, no serial ports, I assumed I need only a usb to serial cable adaptor so I could connect up with the plc's within the factory I work in. I was told that for the adaptor to work, I would have to load drivers into the devices that I was trying to connect to. I was told this by someone at an electronics store. Should it work just fine without any drivers when trying to connect to a plc?
Yeah, those electronics store salespeople have a wealth of knowledge about PLCs... :rolleyes:
You'll find some good information about USB to serial in THIS thread... đź““
beerchug
-Eric
From my personal experience,If you use Omron PLCs do not use Gold X from AD.
It is total disaster the PC boot during On line without any reason.
PCIMCA is better option according to my opinion.
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
108
Hi guys, This my first time posting hope I get help in my issue.. I have Allen bradley control logix safety PLC (1756-L61S) connected with...
2,305
Hi All, I have 2 ControlLogix 5570's that are supposed to each send each other some info over Produce/Consume tags. For convenience, I'll call...
2,713
Hi, To give some context of the situation and why I'm posting. I started a PLC module as part of a general engineering course last year and the...
2,028
Hi everyone I have a Harvest VFD VB5N 0.75Kw it have an ethernet port and RS485 is it possible to control it with s7-1200 plc via the ethernet...
1,296
