Inexpensive PLC with some memory capacity?
friendlyfire
Jan 2008
Comox
Hello,
Does anyone have any suggestions for a simple controller that can also handle a datalogging task? I have an application that requires basic control with four or so digital out, a few digital inputs, and a five or so analog in. Most of the analog in just needs to be recorded, although a couple of them feed back into the control loop.
The PLCs I've looked at don't have much memory capability and therefore won't do a good job on the data logging side. I could go with a cheap PLC plus a stand alone data logger, but there may be a requirement in future to hook everything to a SCADA system and then things will get messy!
I think I need around 100K of memory for saving the data by the way.
thanks
FF
Omron CJ1H-CPU66H features 256KWords data memory.
For sure some other brands may have what you need as well.
Not clear though what to be considered inexpensive.
Omron is a good value usually.
This has truck loads of programming memory, if all you are wanting is to log data, then this could possibly be an overkill. For logging, you need memory areas to store your data, not programming memory.
Check this out, not sure of the pricing, could be what your after?
http://forums.mrplc.com/index.php?showtopic=12204&hl=
PLCs are not very good dataloggers.
We use the AutomationDirect DL-06. It has about 7000+ 8 bit words of user memory.
However what type of data you need to log greatly effects how much you can log. For example if you want to log time stamped error events with the DL-06, that's not much memory:
Date = 3 words, (Day, month, year)
Time = 3 words, (Hour, Min, sec.)
Error code = 1 word. (lookup error code in manual)
That's 7 words per event. = Max 1000 events.
Omron CP1L. Even the smallest model (8 DI + 6 DO) has 10K, 16 bit words data memory apart from 5 KSteps program memory. The 30 I/O model has 32K, 16 bit words data memory and 10Ksteps program memory. These are quite cheap. They have very good instruction set and supports Ladder, Function Blocks (Ladder and Structured Text).
SVN
I would look at Red Lion. I use the Data Station Plus for Data Logging and I am pretty sure they have expandable I/O available for it. The DSP uses a CF card for storage, so memory wouldn't be a problem.
Hello, thank you for all the suggestions. I'll check some of them out. Note that it important that this memory is non voilatile. I do not want to lose all the logged data if the PLC loses power.
Jesper: I suppose it is a RTU application according to the definition I just looked at. I thought RTUs only acquire data and don't offer control capability. This said, I did a quick internet search for RTU products and I don't see any with control features. So, other than PLCs (and embedded controllers) what hardware would you suggest?
Scottmurphy: thanks for the suggestion re Omron. I'm calling the rep now about it.
I should also mentionthat I am seeking a solution around or under the $1000 price point, and prefer something IEC61131 compliant. I'm looking into the FP Sigma from Panasonic but I'm not sure if it fits the budget.
thanks again!
Take a look at the Horner Electric XLE operator control stations:
http://www.heapg.com/Pages/Products/products_OCS_X_xle.html
You may need to add an expansion analog module, depending on the number you want to monitor. The XLE has a slot for an optional MicroSD card, and has instructions to write data to the card in CSV file format. It can also be programmed in either standard ladder, or in IEC61131. The price on this is pretty competitive to other options.
I 2nd the XLe from Horner.
The analog module can be added to it, no special networking options and such, just easy setup (Cscan Smart Stix) and you are up and running.
MicroSD as mentioned for logging all your data.
And it does come with 2 Analog Inputs/2 Analog Outputs (depends on the model).
Have you seen the CJ1H specs?
I said 256K DATA memory.
I believe that it is quite common with at least some limited control capability. A typical application for an RTU is to sit in some remote location and control a well for example. If there is trouble it will send an SMS or email. And it is possible to connect to it and upload a weekly logfile.
A qick search found this vendor (look at the "intelligent" RTUs): http://www.iclinks.com/
They support all IEC61131-3 languages.
edit: also look at this vendor: http://www.sixnetio.com/html_files/products_and_groups/rtu_benefits.htm
I dont know pricing, like in all other aspects, I guess you get what you pay for.
Disclaimer: I dont work with RTUs.
I want to buy used/inexpensive (under $500) PLC hardware and software for personal use/testing. Can any of you suggest the best way to go about...
46
4,800
I need an inexpensive PLC for home automation projects. I only need digital outputs and analog inputs. Pretty simple and slow process. Also, it...
33
12,063
Hello all. I am looking for a very inexpensive PLC in HMI for a very basic control scheme..... a couple of discrete inputs and outputs with a...
18
5,699
Hi, I have a project to replace an old BBC Procontic B PLC by a modern PLC on a Flexographic Printer for plastic film. The app is quite simple...
47
21,734
The company I work for manufactures electrical equipment and our latest product is a voltage monitoring device that triggers alarms if the voltage...
3,779
