Twincat 3 - dynamic matrix size
naturephoenix
Jan 2015
Vienn
181
Hello guys
I have an object actually FB. Inside my FB i got matrix which size I want to be declared once you create instance of my object in Main program. I have done like this: Input parameter of my FB is ppMymatrixPointer : Pointer to Pointer to Lreal; but inside program Iam not sure how to use it this pointer to pointer since this is not working ppMymatrixPointer[x, y].
Hello guys
Ialso have pPointer : Pointer to Real; but inside my FB program Iam not sure how to use it this pointer to pointer since this is not working ppMymatrixPointer[x, y].
I put
pPointer := __NEW(pointer to real, x) ;
ppMymatrixPointer :=__NEW(pointer to pointerto real, y) ;
a pointer from a pointer is not working good, as you are talking about memoryplaces of memoryplaces. and that is no good.
Admittedly, I have never used TwinCat, but I have never seen a PLC that allowed for dynamic array declaration. What I have seen the ability to pass an array in as a type of pointer, and then use whatever operations I want. The actions aren't stored in a local version of the array, they go straight back to the original.
Wherever the array is declared, it is fixed at compile time, but you can process it dynamically. This prevents things like memory leaks, but still allowed a lot of flexibility.
My goal is to pass size of matrix so just INT to a FB where I make matrix. Operafor __NEW allows that. ITS like mallic in C.
In my example pPointer[] works but ppMymatrixPointer [x,x] does not
Hi, What is the best way to set dynamically time for TON timer ? Time should be in ms. Example: timer1: TON; calculatedTime : UINT...
3,109
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
74
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
106
I am developing a library in twincat and one of the function uses IID_ITcVnAccess_TcVnPoint2_DINT and the definition of this type is defined in...
72
