Micrologix 1400 PWM behavior
wpuryear
Dec 2011
Athens, GA
23
I have a couple of questions regarding the PWM output on a Micrologix 1400 BXBA. The 20 KHz output shown in the attached photo is being fed to a high speed counter input. The low level is roughly 12 volts which is not low enough (1.5 volts) for the input to recogize it as "off". Is there a way to configure the PWM output to be used with a high speed counter input?
The other question to reveal my ignorance, is that if I instead route the output accross a resistor of any value, my scope does not see the square wave but a constant 24 volts.
Any insight would be most helpful.
Walt
I can't really help you without knowing how you have it wired. Draw out the entire circuit and show precisely where you are measuring from.
PWM on the 1400 should be able oscillate from +24V to near 0V if it is wired correctly.
■ COM 0 ------------- -24 ----- scope
■ IN 0 ------------------------- connection
■ OUT 2
■ VDC 2 ------------- +24
Your scope should be on the negative supply of the 24 volts (COM2) and OUT2 (assuming you are using OUT2). But you aren't showing a COM2 connection in your diagram.
COM 2 on the output terminal block needs to be tied to 24VDC common, just like COM 0 is in your diagram.
Hello, i am beginer to pwm control and I have a project coming up that requires pwm control of 3 solenoids. Would the micrologix 1400 be capable...
1,171
in micrologix 1400 we have to enter duty cycle to get particular duty cycle.But i want my duty cycle changes according to values coming from pid...
2,620
I have a ML1400 BXBA. I wire the 24V to th VDC2 and 0V to the Com2. And I tried to produce a square wave of 50% duty cycle with frequence 100Hz...
4,144
Hi, i'm kind of new on programming with RSLogix, i've read a lot of documentation about my problem, but i just can't fix it... I want to generate...
5,209
87
