ENA-nbruins
Hello
I am currently having an issue with setting up a AB Micrologix 1200 system with a 1762-OB32T output card.
When setting up the card in the I/O Configuration it sees the card as 'Other' with the description being 'I/O Module - ID Code = 100'.
I tried uploading the program to the controller and it gives me this error
"WARNING: 'Other' card detected - no current load was taken into account for the card(s)"
I did see there was a similar post made in 2010, but no solution was given. I also see that there is some info on the rockwell knowledgebase but its behind their paywall.
Has anyone figured it out? Is there anything I can do?
Cheers
Cheers
