Wago smart printer
diat150
Mar 2006
Louisiana
1,474
anyone using this thing to print terminal markers? Its pretty expensive but seems like in the long run you would easily be able to recoup your money. the terminal markers are expensive and you waste alot of the numbers due to needing lower numbers mostly.
Also, the the marker strip seems like alot cleaner look that the numbered markers.
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
79
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
120
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
347
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
342
How do you set up a message block for a REMOTE IO unit? (using ethernet IP)?
594
