Beckhoff R I/O to AB CLX
ArikBY
Oct 2003
Oranit Israel
1,434
Hello Everybody
I trying to connect AB CompactLogix L32E V17.0 To Beckhoff IL2302-B905.E/IP Remote I\O
When I use Instance 2 Int Input and 2 Int Output the communication show OK
but no option to see the I\O any other trying show error.(On the module have 4 inputs and 4 outputs)
I used BK9105 in the past and they worked OK and configured in seconds.
It look like firmware problem.Any one face that problem?
Shalom!
Regarding the: Beckhoff IL2302-B905.E/IP Remote I\O ....
Tell us a little more about this please. I am very interested. Are you integrating between brands via Ethernet? Does Fieldbus come into play?
Hi, I am currently working on a project and I have to exchange datas between a Beckhoff TwinCat 3 CPU C6925-0010 and a AB Control Logix. I was...
1,856
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
992
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
98
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
126
I have a Beckhoff CX7000 IPC with some digital I/O built-in and I additionally need two analog inputs 0-10V. Can I install both Ethernet terminals...
205
