Is it possible to change VisionView settings through FactoryTalk?
Walks
Jun 2018
Midwest
47
I'm working with a HMI using FactoryTalk ME. VisionView is launched from the HMI and displays the barcode scanned from a Dataman 262. If a barcode does not match the one selected in the FactoryTalk program I would like for the VisionView software to show the red box around the scanned barcode. Currently, as long as ANY barcode is successfully scanned, VisionView will display it as passed with a green box.
I know this can be done from the VisionView settings by manually entering the barcode in the 'Set match string' option. However, I want to make it so that if I select a barcode string from a preloaded list in FactoryTalk then it will load that string into the Visionview, i.e. make it so there is no reason to go into the VisionView settings to change the barcode to be matched.
Hi guys, I am facing problem on layer palleatizer machine.my problem is I can not change the pattern. it is running by present pattern.There is...
1,480
1,423
This is a CompactLogix L33ERM, version 30 (31 is too unstable on my machine to work with), with a Kinetix 5500 drive. I have a program where...
2,011
I'm trying to write a "Universal" program and I'd like to be able to dynamically change the color of an object in FactoryTalk View ME by reading a...
1,925
Long story short, i have a PV1000 that went bad, has the C8 (DH+) communication. I have another brand new PV1000 but has the C15 communication...
1,499
