############################## --------- START20200318102121 --------- ##############################
10:21:21| |CreateExtractionLogFile |Master Log File : C:\ProgramData\Siemens\Automation\Logfiles\SiWA.log
10:21:21| |SiWA Masterframe Version |03.05.01.00_01.01.00.10
10:21:21| |GUI Mode |Full GUI
10:21:21| |CSiWAInitalizer::Init |Initializing the package settings
10:21:21| |PackageName |SIMATIC STEP 7 Basic V14.0 SP1
10:21:21| |Date |Wednesday, March 18, 2020
-------------------------------------- System Information --------------------------------------
10:21:21| |RAM Size |4.00 GB
10:21:21| |Processor 1 |Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
10:21:21| |Processor 2 |Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
10:21:21| |Processor 3 |Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
10:21:21| |Processor 4 |Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
10:21:21| |Computer name |T440
10:21:21| |Space Info on Drive: C:\ (NTFS) |Total Space: 465.76 GB Used space: 325.71 GB Free space: 140.05 GB
10:21:21| |OSVersion |OS Version : 6.1.7601.2
10:21:21| |OSVersion |Major Version : 6
10:21:21| |OSVersion |Minor Version : 1
10:21:21| |OSVersion |Product Type : 1
10:21:21| |System Language |Croatian (1050)
10:21:21| |UI Language |English (1033)
10:21:21| |InitAutolaunch |AutoLaunch is enabled
10:21:21| |SetWaitForAutoLaunchParam |Invalid value for WaitForAutolaunchFinish. WaitForAutolaunchFinish is enabled by default
10:21:21| |InitCommandLineForNoOSCheck |Setting NoOSCheck from INI file.
10:21:21| |InitCommandLineForNoOSCheck |NoOSCheck has been set.OS check will not be done.
10:21:21| | |Windows7ExtractPath :
10:21:21| | |Windows61ExtractPath :
10:21:21| |CSiWAInitalizer::ValidateAndCheckExtractPath( |Extract Path from Web Package : %TEMP%\SIMATIC STEP 7 Basic V14.0 SP1
10:21:21| |CheckFreeSpace |Drive C:. Available space : 140.05 GB
10:21:21| |CheckFreeSpace |Required space : 5.51 GB
10:21:21| |CheckFreeSpace |Comparing Available space : 150372401152 Bytes and Required space 5917249161 Bytes
10:21:21| |Display Name |STEP 7 Basic V14.0 SP1
10:21:21| |GetCheckAdmin |Admin rights needed for extraction
10:21:21| |ValidateOSBeforeExtraction |NoOSCheck is set
10:21:21| |Setuptype |PLUS
10:21:25| |IsParameterFileNotCorrupt |Generating hash code for : C:\{522E0D77-A2E6-4B98-A21B-61A2511FC48F}\Properties_SiWA.ini
10:21:25| |SetSelectedUserLang |Setting the radio button for LanguageID : 1033
10:21:26| |IsParameterFileNotCorrupt |Generating hash code for : C:\{522E0D77-A2E6-4B98-A21B-61A2511FC48F}\Properties_SiWA.ini
10:21:26| |NonameFunction |Autolaunch is enabled
10:21:27| |DirChangePage::OnWizardNext |Overwrite check box is unchecked
10:21:27| |ValidatePathAndSpaceAvailable |Validating the Extract path : C:\Users\Nhjhj\AppData\Local\Temp\SIMATIC STEP 7 Basic V14.0 SP1
10:21:27| |ValidatePathAndSpaceAvailable |Checking the space availability in : C:\Users\Nhjhj\AppData\Local\Temp\SIMATIC STEP 7 Basic V14.0 SP1
10:21:27| |CheckFreeSpace |Drive C:. Available space : 140.05 GB
10:21:28| |CheckFreeSpace |Required space : 5.51 GB
10:21:28| |CheckFreeSpace |Comparing Available space : 150372302848 Bytes and Required space 5917249161 Bytes
10:21:28| |ValidatePathAndSpaceAvailable |Extract Path : C:\Users\Nhjhj\AppData\Local\Temp\SIMATIC STEP 7 Basic V14.0 SP1\
10:21:28| |ExtractPackage |Extracting the Setup to : C:\Users\Nhjhj\AppData\Local\Temp\SIMATIC STEP 7 Basic V14.0 SP1\
10:21:28| |ExtractPackage |Checking for parts
10:21:28|ERROR |ExtractPackage |Multi part File not found : C:\Users\Nhjhj\Desktop\PLCs\SIEMENS\TEMP for step 7\SIMATIC_STEP_7_Basic_V14_SP1.001
10:21:41| |Temp directory : |C:\{522E0D77-A2E6-4B98-A21B-61A2511FC48F}
10:21:41| |Deleting folder : |C:\{522E0D77-A2E6-4B98-A21B-61A2511FC48F}
######## --------- START SUMMARY 20200318102121 ##############################
10:21:41|RETURN |STATUS |Fail
10:21:41|RETURN |ERRORS |1
10:21:41|RETURN |WARNINGS |0
1 Errors found and 0 Warnings found
############################## --------- End --------- ##############################
