FT ME Button... Impossible?
Ruskied
Jul 2018
Valencia PA
19
How would I go about creating a button in FactoryTalk ME with 2 tags and 4 states??
One binary input and one binary output; these tags are independent of each other! Four states (imagine a real button with a light): Up and Off, Down and Off, Up and On, Down and On.
This is a simple task but seems impossible...
I've tried two approaches:
1. Overlay a binary 2 state button on top of an indicator with a visibility animation. Where the buttons were tagged to the input and visibility animation to the output. ---- It only works as long as the animation is not null; I need buttons to be visible when tags are null.
2. Multistate button with 4 states (one for each image) and 4 AND expressions within Indicator connection for all 4 combinations of 2 tags. The "value" connection is addressed to the binary input. It works only if i'm okay clicking through all the states (4) and since it's a binary tag last two clicks don't do anything (if states are 0, 1, 2, 3: sending the value of 2 and 3 won't affect the tag). I need the button to have binary input but multistate output.
I'm coming to a conclusion that what I'm trying to do is simply impossible.
VBA editing isn't available with ME version.
I've started looking into Macro buttons but don't want to waste time if it won't help.
Any ideas? Thoughts?
Regards
I did something like this a few years back at a different company. If I recall correctly, I used a multi-state indicator on top of a pushbutton object.
For the indicator states, I used an expression something like "InputTag + 2*OutputTag". So:
0 = input off, output off
1 = input on, output off
2 = input off, output on
3 = input on, output on
Is this the kind of idea you're looking for?
Exactly what I was looking for! I will try this for sure! Did you make the button invisible but clickable? I suppose making the button transparent without any images. So simply but I couldn't think of this, thank you!
I believe you want to make it transparent with the size slightly smaller than the multi-state indicator. Making it invisible would likely disable the button.
FactoryTalk View ME running on PanelView Plus 7, connected to Compact GuardLogix 5380 PLC Customer is asking for a physical push button to be...
180
Hi everyone Is it possible to change a button image in FactoryTalk View SE (v13.00) using VBA?
77
I was looking for this function, so that i doesn´t need to do it in the PLC. If there are an alarm in the alarm list, i want to flash the...
496
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
529
Hello all, I am working on a project where i am converting an old Siemens HMI to a Panelview. On the siemens HMI, there are features where you can...
510
