TIA Portal V15.1 Sp1, Professional, Toggle Bit in HMI
Ken Moore
May 2004
North, West, South Carolina
3,473
I have a IPC427E, TIA Portal V15.1 SP1, WinCC RT Professional.
This is a touch screen application, and I want set a bit on Click, and reset on Release, but under Events, there is not a Release.
Does anyone know of a work around? I am basically trying to configure a momentary Push Button.
I've only used the KTP700 Basic touch panels and I use the setwhilekeypressed event - I take it you do not have that option either?
Ken
Since its a PC with a separate touch screen and drivers..
What happens when you press it? or any place on the monitor
Does any input tool open too? ie setpoint (numeric input)
Click is my only option for the touch screen, many options for a mouse.
I wonder if Advanced version has more options.
"Press left mouse button" - is your touch
"Release left mouse button" - is your release
I am using IPC477D and IPC677D both touch screen and it is working well.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
438
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
351
Hi everyone i'm trynna install Tia portal v15 The installation starts normale but it suddenly stops asking for a reboot , When i restart the...
32
8,244
Hi I have tia portal professional 15.1 and 16 on VMware , I have an issue where I can’t add a 1500 cpu I can open projects which is using a 1500...
2,585
Could not figure out how to enter AT Overlay. Has Siemens cancelled this feature? Also, how do we create a DB or IDB not by the...
3,753
