plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 11th, 2019, 11:12 AM   #1
cottagewood
United Kingdom
cottagewood is offline
S7-300 I-Device config
I have a 315-DP/PN and a 315-DP with a CP343 card and I'm trying to configure i-device. The step 7 5.5 help gives a step by step with screen shots, however, I've followed it and I don't have all the tabs that are shown in the help, specifically, I don't have the i-device tab and check box for i-device mode
I just have these 4 tabs for the interface
Does anyone have any ideas?
Old January 11th, 2019, 11:58 AM   #2
travispedley
United States
travispedley is offline
Honestly, I only use i-device if someone makes me. Much easier to use netpro to create a connection and use AG_Send / AG_Recv in my opinion.
But, i recreated what you described and i-device appears in both processors without an issue. What 343 card are you using?
Old January 11th, 2019, 12:18 PM   #3
cottagewood
United Kingdom
A cp343-1 lean,
I hadn't even got as far as configuring that side, I stalled at configuring the i-device on the CPU315-dp/pn
Old January 11th, 2019, 12:40 PM   #4
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
Which version of the 315 are you using?
Old January 11th, 2019, 12:42 PM   #5
cottagewood
United Kingdom
V3.2
Old January 11th, 2019, 12:51 PM   #6
L D[AR2,P#0.0]
United Kingdom
If I use the 3.2 f/w from the h/w catalogue, I get the i-device tab, if I use the 2.6 f/w or below then I don't
Old January 11th, 2019, 01:06 PM   #7
cottagewood
United Kingdom
I had more than 1 config open at the same time, I closed them all and open just the 315-pn/dp and I can see same, thanks every one for you help
Old January 12th, 2019, 01:30 AM   #8
cottagewood
United Kingdom
Gee, I thought this was going to be easy but I'm still struggling with it.
I can't use i-device because the CP343-1 lean is not an io controller so I can't add the i-device i created on the CPU315/PN from the catalog.
So then I tried to use iso-on-tcp but netpro will only let me partner 2 CP343's and not a CP343 to a CPU315/PN
Anyone got any other ideas?
Old January 12th, 2019, 07:35 AM   #9
Lare
Finland
Lare is offline
You can use put and get blocks on 315 pn/dp and read from / write to datablock areas to CPU with 343-1 lean.
Old January 12th, 2019, 12:50 PM   #10
wimpiesplc
Netherlands
wimpiesplc is offline
maybe this document can help, section 21.4.2 is about S7-300/S7-300
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
S7 300 and S7 200 CPU Communication faisal rasool LIVE PLC Questions And Answers 3 October 25th, 2015 08:37 PM
comparison of s7 300 & s7 1200 janardhan26reddy LIVE PLC Questions And Answers 7 January 12th, 2015 02:15 PM
S7 300 PLC and Indramat arturnok LIVE PLC Questions And Answers 0 November 3rd, 2012 11:45 AM
s7 300 and 400 master slaving moazzim LIVE PLC Questions And Answers 16 April 10th, 2007 05:52 AM
S7 300 to wonderware connection gherz817 LIVE PLC Questions And Answers 1 January 25th, 2007 09:47 AM
