mostapha Member M Join Date Jul 2015 Location beirut Posts 9 Jul 1, 2015 #1 how can i generate a pulse of high frequency of range 500 Hz to 1.5 KHz with 313C i want to generate the pulses to control a stepper motor??????
boneless Lifetime Supporting Member + Moderator Join Date Feb 2008 Location OKC Posts 1,628 Jul 1, 2015 #2 Double click COUNT under the CPU in the HW Config window. And choose PWM.
mostapha Member OP M Join Date Jul 2015 Location beirut Posts 9 Jul 1, 2015 #3 how can i learn more how to use these channels and how to use them in my program?
boneless Lifetime Supporting Member + Moderator Join Date Feb 2008 Location OKC Posts 1,628 Jul 1, 2015 #4 You can check out the technology manual: https://cache.industry.siemens.com/...ctions_operating_instructions_en-US_en-US.pdf Page 222 has an example
mostapha Member OP M Join Date Jul 2015 Location beirut Posts 9 Jul 1, 2015 #5 thank you so much for the information regards
mostapha Member OP M Join Date Jul 2015 Location beirut Posts 9 Jul 2, 2015 #6 i did not fully understand how this function work how can i get more details about pulse function for s7 313C
PeterW Member P Join Date Jun 2006 Location Calgary, AB Posts 2,531 Jul 2, 2015 #7 Looking at the manual, section 7 is for controlling. You need to choose a SFB for the control: ● SFB 41 for continuous control (CONT_C) ● SFB 42 for step control (CONT_S) ● SFB 43 for pulse width modulation (PULSEGEN). Read up on this section
mostapha Member OP M Join Date Jul 2015 Location beirut Posts 9 Jul 2, 2015 #8 i am trying to use the SFB 49 that have the name pulse, but i did not fully understand how to use to it?
mostapha Member OP M Join Date Jul 2015 Location beirut Posts 9 Jul 2, 2015 #9 i am trying to use the SFB 49 that have the name pulse, but i did not fully understand how to use it?
mostapha Member OP M Join Date Jul 2015 Location beirut Posts 9 Jul 3, 2015 #10 how can i use SFB 49 in my program?
mostapha Member OP M Join Date Jul 2015 Location beirut Posts 9 Jul 3, 2015 #11 how can i use SFB 49 to generate PWM anyone has an example?
boneless Lifetime Supporting Member + Moderator Join Date Feb 2008 Location OKC Posts 1,628 Jul 3, 2015 #12 In stead of posting the same question 4 times, use google and do some research. It took me a whole 2 minutes to find this: https://support.industry.siemens.co...modulation"-of-the-s7-cpu-31xc?dti=0&lc=en-US
mostapha Member OP M Join Date Jul 2015 Location beirut Posts 9 Jul 4, 2015 #13 i have already seen this and i shave spent hours searching not 2 minutes thank you any way
