scottmurphy
- Join Date
- Oct 2004
- Posts
- 363
I have asked similar before, and I know there is plenty of PID info on this forum, what I am asking though is there anyone out there that is done much with Web tension control systems? We have an old wallpaper machine that we have replaced the DC motors and control systems with a servo and plc. There is a standard indiction motor on the lead nip that runs at a fixed speed, and then we adjust the torque on the trailing nip to adjust the tension.
I have the pid tuned pretty well for tension SP changes when running at a fixed speed, the problem is that if we give a large SP on initial startup, then it seems to take to long to acheive the requested tension.
I know this sounds like a tuning issue, I haven't been back to try and tune the loop even faster. The biggest issue is that there cannot be any hunting, and since is it paper, any overshooting can cause paper to break and possibly cause fires
The main reason for me posting this is to see if there is anyone that has had any experience with tension control system?
