Problem communicating plc to factory talk site edition
kevj11
Feb 2017
Ontario
Hi all,
I am currently working on a project involving the use of a Micrologix 1100 PLC with RSlogix 500. With the program downloaded to the PLC, I can only control using the physical application. But When I try to toggle a bit, it will not do anything. It will only work when I force it ON. Can anyone help me fix my program where I can toggle a bit ON and not force it ON. The reason I'm doing this is because I'm trying to communicate with factory talk site edition and when i press a button using the site edition it is not toggling anything.
Is the bit the operand of an output instruction ? It sounds like you've got a physical output that is controlled by an OTE or OTL instruction.
Tell us more about the logic and the addressing.
You can't toggle an input or an output you have to force them. You can toggle a bit if nothing else in your program is controlling it.
Hello, I am new to this group and to the plc. I am trying to connect the plc-5 to my computer using usb serial adapter. I am going to configure...
17
3,981
I have a TP170A panel. I want to connect it to PLc via PROFIBUS. I use wincc flexible 2007 and STEP7 5.2. Meanwhile installation of WinCC fl. , it...
5,870
Good Morning All, I worked with Automation Direct and Allen Bradley for the last 20 years. Now I have a new job working with Omron. My first...
2,649
Hi I am having a problem with connecting to a plc at work.It is a modicon micro 110 CPU 411 00. I am trying to connect using Proworx 32 trial...
1,306
I have a Micrologix 1500 configured with a 1769-SDN communicating with 1769-OB32 24VDC output module using a 1769-ADN. The Micrologix reads the...
2,168
