Omron CP1L
If your input is coming in at 500Hz you should just use a regular input to do the counting. Your scan time of the PLC will be under 1msec.
I don't think that's a good idea. It is relatively easy to get a CPIL program up to 3-4 ms scan time.
The CP1L already has built in high speed counter inputs so why not just use them??
The program is not developed yet. I would develop the program with a regular input. If the speed is too quick for the input then program the high speed counter.
In the meantime, you have all of the logic programmed and tested.
Regards,
Hi everyone! I have an issue with some Omron CP1L-E PLC's. They're connected to get the info from production machines, but I've noticed that...
1,147
Hi! Omron CP1L. CX Programmer. How do I fix so that a CNTRX(548) remembers the count it had before a power failure? I need to know how many...
1,388
Hi! Newbie here... Cx-programmer CP1L PLC NB7 HMI I want to multiply something i by 1,5 in CX-Programmer to get a higher number to use in HMI...
2,206
Hi all, I've been upgrading some machines recently which involves installing a 10" NB HMI, HUB and a CP1L-E to avail of the built-in ethernet...
1,698
Hi, is someone experiment connecting a Omron plc CP1L with a Siemens HMI TP1200?, i've installed the drivers in WinCC , plc options is just CS1 or...
1,903
