FactoryTalk View SE start DataLogging from the startup macro
JEANST
Jun 2015
PARIS
68
Hello all
I have a question, concerning datalogging in FTViewSE 8.0
I have 2 datalog models with 2 differents recording rates (30s for live datas and 1h for Energy counting datas) .
so i can't start if both from the classical way of Startup properties.
I would like to use the DataLogOn function and launch it from the Startup Macro.
And it don't works...If i manually launch the datalogon function from the administration console, it's ok.
If somebody have an example or another way to do it.. ?
Good Afternoon, Just upgraded FactoryTalk View to 8.2 . Worked great the last 2 days. Opened another application it asked if I wanted it in...
7,852
Once i finished preparing to add three analog values to be on trends, then i stopped the datalog models and it was working ok but starting back...
1,526
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
123
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
152
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
118
