Physical security for Run-Time USB license key-dongle
danw
Oct 2004
midwest, USA
3,427
The HMI software's run-time USB license key has nice hole in the end.
What do you guys use to secure it so it doesn't walk away?
When I have an expansion USB header off the mainboard, I put the dongles inside the case. Just have to remember to retrieve them when replacing the boards lol...
I have actually used a usb extension board that plugs into the motherboard. Then I mount the extension board INSIDE the PC case for the license dongle.
Along the same lines.... if you use a USB extension cable plugged into the back of the PC and ran into the PC cabinet it would be 'out of site' then you can use a wire tie to keep it secure in the PC
FactoryTalk View ME running on PanelView Plus 7, connected to Compact GuardLogix 5380 PLC Customer is asking for a physical push button to be...
181
Hi folks, In a new project, I'm trying to define variables with physical address like N7:xx, F8:xx,... I need physical address variables to...
751
1756-L82ES controller, V33 lastest firmware using a Sick brand encoder to monitor position on the shaft of a conveyor. (call this conveyor) I...
1,196
Hello everyone, I'm a beginner technician in Brazil in automation. I provide services in a company that does safety installation work in various...
1,216
I want to start using a VM for all my programming instead of my computer and wanted to see what is the best way to get my physical machine...
1,464
