Siemens S7 300 PLC with Visual Basic
vikas.vvs
Apr 2007
sharjah
25
Dear Friends,
I am tring to connect S7300 plc with M S visual bacic for plc data read/write of PLC registers/memory
Can any one help me in this issue?
Thanks in advance
vikas
Basically you should configure:
1. OPC Server - how to do it - nearest is doc: "How_to_set_up_OPC_with_Simatic_Net.doc". See this site Downloads/Siemens
2. OPC Client for using with VB. There are many of them in WEB. For Example - on the site of KepWare. You could download it with the code samples and Help.chm.
Regards, YuryAS.
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
687
Is there a version of Siemens software that can be used to view only the installed program logic and diagnostic buffer to determine system and bus...
2,090
Dear Friends; We have a BOBST 1228 flexo printing machine having Siemens S7-300 PLC (6ES7 318-3EL01-0AB0) and Lenze 9300 and 9400 drives. The...
2,305
I set the Date and Time of the S7 300 PLC equal to that of my PG. But after a few days I found that the date and time were not what they should...
1,914
Hi Can any one give me some of sample project file for Siemens S7 300 PLC that I can practice at home. Thanks in Advance
2,793
