GE CPE310 USB Project Download
LMBrian
Sep 2012
Florida
54
I am using a USB stick to upload a project from a CPE310 and download it successfully to another CPE310. Is there a way to back-up my project using PME 7.5 to this USB in a suitable file format so that I can then download the project to the controller using the USB?
Thank you,
As far as I know there is no way for Proficy Machine Edition to open the files uploaded through the USB port via the RDSD procedure.
AFAIK, Steve is correct and there is no way for Proficy ME to load files to a USB drive that can then be loaded to a CPU via its USB port.
Rather 'short-sighted' of GE eh? :confused:
I did suggest this be changed at one time, maybe if more made the request it will be.
Thanks Steve and Russ,
I believe you're correct. It's not the end of the world, just a bit of a pain though.
Thanks again,
Brian
Hello everyone, I need your help. At one of my company instalations we have GE90-70, and we're going to replace it with some newer PLC. I prefer...
508
Hi, I have an Rx3i IC695CPE310 and I need to be to read/write to the cpu registers (4xxxx / %R) using modbus. It look like the plc is set to a...
2,716
I have a 12 slot RX3i rack with I/O, CPE310 processor, (with embedded ethernet), and ETM001 comms module. The ETM001 is used for comms with...
2,068
Hi - I am converting and existing 90-30 series PLC system with the following: Rack 0 has power supply, CPU, and 8 Horner 4-20mA input modules...
3,999
please using the usb can i assign any ip address that i want ?
148
