Tag Export from RS Logix5000
Chris Taylor
Feb 2011
Canterbury
257
I'm just having a little problem exporting tags, some of my tags have arrays.
I can export but I only seem to get the tag and not the complete array.
I can't find a setting in options, I guess its someting stupid RSlogix 5000 V19.01
Many Thanks
The tag IS the array - the export only gives you the tag structure, not the contents - see the pic
Don't know if I understand what you are looking for that daba did not show, but if you are wanting the actual data from the array, you can export the whole program as a L5K file and there will be a section for tags that contains the array definitions and the data in the array. It would look something like this:
TAG
ct : DateTime (Description := "Current Wallclock DateTime") := [2011,5,6,11,17,12,465166];
CurrentMovingAverage : REAL (RADIX := Float) := 9.69449580e-001;
MAVEDataArray : REAL[40] (RADIX := Float) := [2.79415637e-001,9.58924234e-001,0.00000000e+000,2.82240182e-001,0.00000000e+000,1.68294179e+000
,0.00000000e+000,1.91021442e+000,0.00000000e+000,4.36164618e-001,2.08620930e+000,1.99951041e+000
,2.23515105e+000,1.18777955e+000,1.97325552e+000,2.01068425e+000,0.00000000e+000,1.90750682e+000
,7.68252850e-001,3.70727509e-001,3.60715795e+000,8.50902081e-001,0.00000000e+000,1.66354966e+000
,0.00000000e+000,3.17244947e-001,0.00000000e+000,2.89138600e+000,2.96368450e-001,6.43539250e-001
,0.00000000e+000,4.28181350e-001,1.05816782e+000,1.99982369e+000,2.14629292e+000,0.00000000e+000
,1.63206244e+000,0.00000000e+000,9.89358306e-001,6.56986415e-001];
MAVEDataToLog : REAL (RADIX := Float) := 5.36573231e-001;
ModData : DINT (RADIX := Decimal) := 1;
MovingAverage : MOVING_AVERAGE := [1,1.07314646e+000,40,1,9.69449580e-001,0,0.00000000e+000,9.69449580e-001,5.52150831e-040,4.90454463e-044
,0.00000000e+000,5.60519386e-044,2.50000000e-002];
MyResetTrigger : BOOL (RADIX := Decimal) := 0;
ResetMAVE : BOOL (RADIX := Decimal) := 0;
SampleTimer : TIMER := [-1071572748,1000,978];
END_TAG
You may also get what you are looking for by selecting multiple rungs and right click on left border and export. When you import into a new program it will also recreate the tags and data in the new program. If there are any UDTs they will also be created before inserting the tags with data.
In the controller organizer you can also select to import/export complete routines, which will work on items other than ladder.
I have created a Compactlogix PLC program with RSLogix5000, and now want to export the tags to PanelView Plus program created with RSView Studio...
11,552
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
280
Hi. When exporting an hmi tag data base to .csv, there are two steps that excel comes up with in choosing the correct format, does anybody know...
832
Hello everybody I work for an organization that treats wastewater. We are in the process of migrating 200 pumping stations to another...
827
Does anybody know of a way to export tags from Logix Designer and have it expand the UDTs into individual tag names? For example, say I have a...
1,722
