FactoryTalk View SE 7.0 to FT View SE 5.10 Problems
ebolbol
Apr 2011
CA
175
Hello gents,
Have you ever ran into this? You have two versions of FactoryTalk View SE, one is 7.0 and the other one is a much older version 5.10
You've developed a whole bunch of new screens in the 7.0 you would like to export to the 5.10 and during the import, 5.10 gives you a whole bunch of import errors. When you try the "Add component into app" method (i.e. *.gfx files) you also get errors.
Yes why don't I just upgrade the 5.10 to 7.0... well... logistically it's complicated... as a main supervisory workstation, I'm not able to disable that machine any time soon... but long term, upgrade is in order.
any thoughts?
thanks
It is pretty standard with most software you can take stuff that is created in a new version backwards. You could create the screens in 5.10 - then import them into 7.00.
FactoryTalk View SE 7.0 to FT View SE 5.10 compatibility
yeah... at the time I made the screens I didn't think they would be as heavily used as they have proved, so I didn't build them on the main supervisory machine which is the 5.10... had I but known, I definitely would have done it on the 5.10 and exported them to the 7.0... now it's too dreadful to have to do all that again manually
there has got to be a way to convert the xml to be compatible with 5.10
Have you tried just opening the 5.1 with 7.0 then just copy the new screens to your Appication. Them When your done just save your run file as a 5.1 ver. then down load it to the HMI.
SE isn't ME. It doesn't work that way.
The easiest thing is probably going to be simply recreate the displays in 5.1, and always edit on that platform from now on.
What errors are you getting?
My assumption is the errors relate to old/missing controls in V5.10... If this is the case you could try manually massaging the export xml file to "fix" the issue.
I have done this a few times while migrating between different production system versions (albeit never from V7). It's a pain in the *** but with a bit of playing it can be done.
(Ps I use XML Copy Editor for manipulating the XML)
Regards Dave
leighigh,
Well there is no HMI downloading involved here as this is Site Edition "stand-alone" that is resident on the workstation(tower) that it runs on.
I think once you open an older version, or copy it into the new application, it converts everything to the newer file structure and can't revert back. I will try what you said... I will copy a couple of GFX's from 5.1 to 7.0 folder in explorer and try to open from within Studio to see what it does...
rdrast,
I think you're right... even though RA can easily make newer versions backward compatible, it's a matter of economics and $$$ I'm sure... they want people to upgrade, which is fine.
Regards Dave
ADoozer,
I have Notepad++ and it allows me to edit XML
so initially I thought it was an easy change, when I got msg1 "Gfx-SE6.xsd' schema could not be found." I simply opened the XML file and changed SE6 to SE4 because that's how 5.10 xmls have. After doing that, I got msg2??? (both msg's attached)
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
120
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
122
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
115
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
196
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
128
