Configuring Two SLCs 5/05 in RS View32 via TCP/IP
AB2005
Nov 2006
Lahore
318
Hi;
Is it possible to configure two SLC 5/05 in RS View32 via TCP/IP and Direct Driver?
Communication is slow if we configure two PLCs via OPC server.
I don't see why you couldn't set this up in RSLinx enterprise. I'm thinking RSView32 is a very old version of the software, so I'm not sure. It was before my time.
RSView32 support four "direct driver" channels. RSLinx Classic is still the data server, but without the OPC layer.
Can you put a number on what you consider to be "slow" communications ? Is it faster if you have just one SLC-5/05 configured ?
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
765
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
585
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
651
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,138
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,256
