Migrating tag history from Wonderware to Ignition
zacslade
Oct 2014
Phoenix, AZ
84
Hi all,
Has anyone here ever converted Wonderware tag history and added it to ignition's historical database?
If so, how did you do it? Are there tools available for it? Did it take a lot of time?
Thanks in advance!
I have not, but I'm hanging around to see because I'm hoping to talk a major client into switching from Wonderware to Ignition.
You won't regret it ;)
best method would be to get the wonderware data into a db table if it isnt already. then you will need to build a cross reference between the ignition tagname and the wonderware tagname. then ignition has a scripting call to store data, you will have to write a python script to collect the data for each tag and then use the scripting function to store the tag history. I havent done it but that is the method I would use if I were going to.
Why would you have to write a script to collect historical data on a tag? In ignition it's as easy as checking a box to enable tag history (and a handful of other parameters). Or am I misunderstanding you?
I think diat150 was talking about importing the WW historian data. Looks like he went through the same thing according to this Ignition forum thread from 2012
Hello everyone, I'm trying to make a spreadsheet containing all the rung locations for specific tags and can't seem to find an easy way to export...
1,518
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
44
We are upgrading our FTV ME v8.1 program to SE v12. Is there any way to migrate the alarm tags (about 600ish) from ME to SE. The import / export...
839
Can it easily be done ? We have a legacy project written on Allen Bradly 1746-l542 with Several racks of some on an extension rack and some on A...
1,746
I just want to get others thoughts on what is the biggest obstacle one faces in migrating to a newer system? For me with the few systems I have...
17
4,114
