juan salazar
Hello everybody!
At the beginning I downloaded a new procedure to the PLC 90-30 and it was ok, after that When I try to download other modification to the PLC, it says something like "error 904 timeout" , I can go online, inclusive I can change some constant values from registers. but when I want to do some modifications in the PLC it´s no possible, I have seen the delays marked relevants in this case, like request timeout (25000) and in global parameters request time (30000) but with these values all same.
If I run "verify logic" also it is not possible
Thanks in advance!!
Juan Carlos
Thanks in advance!!
Juan Carlos
