Siemens Servo motor and another brand servo Drive
md.abdullah
Sep 2011
motihari
168
Dear All,
I have a machine of stone cutting CNC. with Siemens 810D system.
I am very tired to maintain(Servo drive failure) it now wants to switch another PLC based system with limited facilities.
So i want to change the servo drive but i want to keep the servo motor(IFK6 series).
Does it possible i can run Siemens servo motor with any another servo drive
thank you
Dear Abdalla
It looks like a Simotion C230 or C240 Controller.
Simotion C is combination of a PLC a Servo Controller, the Simodrive is the Amplifier, but as I recall in the parameters of the Simodrive , one of the parameters saves the motor type(Motor part number)
I doubt that you can use a different drive for a Siemens Servo motor.
Regards
Hgos
No. That’s not Simotion.
The ET200M I/O is being controlled from the 810.
You Can retrofit this with an Siemens S120 system but the axis coordination is a different story.
Since this current system is a CNC controller... how do you want to simplify it?
I think that is what you mean...
I believe that motor is Permanente Magnet with an encoder
I just replaced one myself. in my case the drive went but we were not sure if the motor was still goon PM motors have a habit of losing their magnetizem we ended up replacing both with a flux vector drive and motor, a lot less cost then repairing them
it worked out great no problems at all
I am assuming that this is a main feeder drive. I would look at doing the same thing if it were me.
I have attached Siemens Servo motor and its vfd which is currently running.
Any other Idea to run these motors with any other VFD of Siemens or any other Brand.
I want to select a servo motor for an application. I prefer it to be Siemens Mechanical engineers are describing the project as Total cycle...
854
I have a newer customer that I've been working with one or two days a week, over the last couple of months. Their automation is Siemens Step7...
20
5,776
Hi all I am looking for 2 siemens servo motors part no 1-1FK7064-7AH71-1SG0 SYNCHRONOUS SERVOMOTOR, 1FK7 2- 1FK7060-5AF71-1SG0 SYNCHRONOUS...
1,439
Good day Wanting to learn about servos, I bought from Ebay, a USED Siemens Sinamics S210 servo drive with the 1FK2130-2AG00-2SA0 motor. The unit...
1,476
Hi Everyone, I am new to siemens servo drives, needs some helps and wondering if you can help me. The machine has Siemens S120 Servo Drvie and...
1,619
