slc500 power up
jthornton
Jul 2002
Poplar Bluff, MO
295
Is there anything one should do when powering up a slc500 plc in the ladder logic? I am using a slc 5/01 processor.
First scan?
I have a simple state program for a case packer with no communications involved.
TIA
Mainly that depends on the program.
IF there's specialty modules involved then ,maybe.
IF you want to be sure certain items in program start at a certain point then , maybe. It all depends on what hardware is involved and how the program is written and if there's a certain operation that's desired at start-up, or should the machine remember where it was when power was lost?
It all comes down to YES, NO, MAYBE.
Take your pick!!!
Drewcrew6
The one thing you will need to do if you are on a DH+ network with other plc's,slc's is to mov the address into S:15(node address)because as far as i am aware the slc does not hold this address.
Hi all, I have an SLC 5/05 PLC installed in a 7-slot rack in an electrical panel. The machine it's installed in has been in storage for the past...
1,406
Hello everyone, I have a SLC 5/03 with two racks, the first with 10 I/Os and the second with 12. The CPU intermittently restarts looking like it...
2,237
Hi all At work we have had some problems with SLC500's faulting out on power up, after being isolated for 6 or more hours. To get round this we...
4,848
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
294
can the slc500 5/05 send a email and text over Ethernet ?
195
