Contrologix5000 & Wondwerware 10: Dynamic Alarm Text Strings
Dec 2016
Southeast
134
Instead of defining static alarm text strings in Wonderware, is it possible to build dynamic strings in the PLC and display those, or is that just not the way it's done with PLCs?
For example, a string that's defined as "Deluge in : X Minutes", with the time inserted dynamically.
Spaderkung:
Thanks for your response. They would be alarms with history.
Would this have to be implemented on the Wonderware side with just an index read from the PLC?
If the WW alarm db stores only tags and dates, then there will be the identical message information in the history. Both the plc and hmi can build dynamic alarm strings though, but I would guess the ALMD plc tag for instance is read full info by the AB hmis only. I have no example how to do this.. but I would focus on ww. For a test alarm tag change the msg and see if the history now shows different msg. Then get the correct msg together with the alarm event.
Hi, Is it possible to execute SQL stored procedure from Wonderware System Platform? If yes, how? Any valid reference to technical documentation...
2,740
Hi We have a wonderware system platform galaxy on which we use a direct OPCClient to connect to a Schneider OFS Server. We we use the...
2,003
As I said in the title, I can't get Windowviewer to communicate. The problem is a bit involved but I'll explain it and hope someone here knows a...
24
14,441
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
217
