Older Rockwell dongle
Jcooli09
Jul 2013
Cleveland
48
I use FactoryTalk SE running on PCs for the facilities I manage and the vessels which service them. We've been on version 7.0 for several years, but we're switching to version 8.4 as we replace the PCs.
We use a dongle to handle the activations, we include a backup in the memory and if a computer fails we have everything we need provided FT has been preloaded onto the machine.
I've run into a problem with some of the older dongles, the 9300-USBELSER.A, which incorporate a RealTek USB ethernet adapter. I downloaded the driver from Rockwell and Activation Manager recognizes it.
The problem I have is when I shutdown, I can't shut down. It begins to shut down normally, but locks up in the shutdown screen. I can shut it down by holding the power button down, but if I don't do that I get a blue screen and the system reboots after about 10 minutes.
Has anyone here ever dealt with this?
My memory is failing me. I seems to remember I could download which ever version of any Rockwell Automation software as long as they are covered...
2,510
Hi, I'm looking for the older style compatibility matrix Rockwell used to have which lists which CPU's are compatible with which ENET/CNET card...
1,681
Hello and Good Day All, We are planning to upgrade controller (from L55 to L75) for a Redundant ControlLogix based system. Following is a brief...
2,005
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
461
Hello, I am trying to streamline an AOI that will get module/controller statuses from ethernet IO tree. Everythings fine, however, does anyone...
1,556
