Hello
I need some sample program for connecting S7 314C-2DP - TP177B 4" DP via Profibus DP.
now i still using MPI for connecting between S7 and TP177B and now i would like to use profibus DP, because i used Sinamic G120 to S7 with Profibus.
on MPI i used direct tag, exmpl. if i make button with tag M0.0. so i read in the PLC S7 is the same M0.0. is't the same procedure if i use profibus connection.
sorry for my english
Thank you
Thank you
