Good Morning ,
I have a quick question about the Powerflex 525 embedded ethernet drive. I'm using a CompactLogix 1769-L18 and using Ethernet to communicate with the drives . I would like to not be "stuck" with using the same drive when replacing it.
If I use
"Disable Keying - the controller will not employ keying."
Does this mean I can use a 7.5 Hp Powerflex 525 to replace a 5 Hp , etc. ?
Thanks so much for your help.
If I use
