Powerflex 525 Embedded Ethernet- Using Disable Keying ?
Rob S.
Sep 2008
Maryland
739
Good Morning ,
I have a quick question about the Powerflex 525 embedded ethernet drive. I'm using a CompactLogix 1769-L18 and using Ethernet to communicate with the drives . I would like to not be "stuck" with using the same drive when replacing it.
If I use
"Disable Keying - the controller will not employ keying."
Does this mean I can use a 7.5 Hp Powerflex 525 to replace a 5 Hp , etc. ?
Thanks so much for your help.
I have used "disable Keying" to ignore firmware major revision mismatches but I have never attempted to try and connect to a different HP drive so im not sure how it would act.
With the PF525 AOP you define the drive type, HP, voltage etc... I cold see a conflict there if it doesn't match. If you tried the PF525 AOP and it doesnt like it you may be successful using a generic ethernet module for your communication.
Just go to the General tab, then change button, match drive.
Pretty simple if want to change to a different drive. And your definition is already defined for a 5hp.
And change your parameters from old drive to new drive that is documented. Its probably going to ask to download I think? yes
Or give you option of replacing certain parameters? edit
This is where it glitches on me so pay attention.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
228
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
233
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
468
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
224
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
294
